Post by gmoore on Jun 20, 2020 18:58:27 GMT
Hello all,
Just having a lockdown P5 headrest fitting and seat adjusting session. All is going well with the adjustment but has anyone fitted the Wadhams brackets?
I note there are two set nuts at the very top of the seat that take the two screw bolts and they hold the part firmly in place in its slot.
There are also supplied 4 x short
3/8ā self tapping screws and two lā self tapping screws. There are two pre drilled holes at the bottom of the part and I suppose two of the small self tapping screws can go in there after drilling the seat back. That leaves four unused screws . There are two holes half way up that line up with the inserted pressure adjustment plate but there is nothing underneath, due to a circular cut out, to screw into.
The whole thing is very secure as is . The two top screws really hold it tight. I just wonder where the other screws are intended to go. I can drill new holes in the part to use them. Any ideas?
Regards
Graham
