Post by stirlingmg on Aug 3, 2020 5:48:29 GMT
Me & my mate are in the process of waking this up from its 27 year snooze
Post by stirlingmg on Aug 3, 2020 5:53:52 GMT
The mag is not producing a spark, so we’ve popped it off & the current owner is going to strip & clean it & stick it in the oven on a low heat for 45 mins which apparently does them some good. It may need to be remagnetised The dynastart still works, at least as a starter anyway
Post by tarnowl on Aug 3, 2020 6:50:39 GMT
Wow, that looks interesting! A bit of a challenge. 😂 What is it?
Post by stirlingmg on Aug 3, 2020 8:54:46 GMT
It’s a one of these🙂
Post by stirlingmg on Aug 3, 2020 8:56:00 GMT
You know, one of these
Post by stirlingmg on Aug 3, 2020 8:57:07 GMT
It’s a Renault O.S.2 dating from 1928
Post by stirlingmg on Aug 3, 2020 13:00:09 GMT
I love the little details like the bearing caps & also note the wheel nuts are narked D for droit (RH) the ones on the other side are marked G for gauche (LH) nice little touch
Post by Eric R on Aug 4, 2020 7:34:07 GMT
right-hand drive?
Post by stirlingmg on Aug 4, 2020 12:43:00 GMT
Certainly is
Post by stirlingmg on Apr 11, 2021 10:17:55 GMT
Update on the little truck. It now runs & drives & goes rather well when it wants to😆 It was running months ago fitted with Phil’s home made distributor drive & an old mini distributor, but had a serious misfire, which turned out to be a holed piston, caused by a bolt being dropped in one of the spark plug holes many years ago. Phil removed the engine & stripped it, welded a new crown into the piston & reassembled the engine. The 2 white metal main bearings were in very good condition, as were the big ends. The valves were very poor so with some measurements taken some Scania ones were obtained & modified to fit. Phil then ran away to Wales where he was working & a couple of weeks ago asked if I could pop the engine back in for him. His work then dried up & he returned home & finished off the installation. He bought a carburettor for a Fordson E27N & fitted it as the original was in a bad way. Yesterday afternoon was spent driving around a field, fiddling with timing & mixture settings & by the end of the day we had some quite impressive performance out of it.
Post by stirlingmg on Apr 11, 2021 10:24:31 GMT
Post by stirlingmg on Apr 11, 2021 10:45:40 GMT
