Post by p5andrew on Sept 10, 2020 18:22:44 GMT
My p5b has developed a problem. The engine starts ok but the starter motor then remains energised and therefore engaged. My initial thought was that the solenoid was sticking. I therefore removed the starter and stripped the solenoid. It was spotlessly clean with no sign whatever of sticking though there was some pitting to the contacts. I therefore machined the contacts and then reassembled all. The problem remains. I then checked for voltage at the solenoid energising wire and it was present-I could have saved myself several hours work had I checked this first, but there we are. I have checked the key switch which is the later type on the column- all ok. I now suspect the starter relay though does not seem very likely. Is this a common problem? Any other suggestions gratefully received.
Post by harvey on Sept 10, 2020 18:59:57 GMT
Sounds like the starter relay stuck on. Should be a 6RA IIRC. I've seen it happen before.
Post by johnwp5bcoupe on Sept 11, 2020 7:53:53 GMT
Sounds like the starter relay stuck on. Should be a 6RA IIRC. I've seen it happen before. It's in the space on the bulkhead between the heater box and the heater motor mounted vertically
Post by p5andrew on Sept 11, 2020 11:51:47 GMT
Many thanks both. I now have a new starter relay on order.
