Post by Eric R on Sept 11, 2020 12:20:45 GMT
will the distributor for the later P5Bs replace the older (1969) ones or do we keep to the older one as fitted please?
Post by harvey on Sept 11, 2020 12:31:21 GMT
Should be a straight swap. What problem do you have?
Post by Eric R on Sept 11, 2020 13:31:56 GMT
I changed P5 Mk1 to Powerspark electronic a few years ago Harvey and never had to touch it since. My 1969 P5B coupe has various issues and the distributor cap needs replacing as do the HT leads etc so why Im dealing with them I thought this might be the best time to upgrade this also. On online suppliers seem to default to the later P5s whereas as far as I can tell my present distributor looks different. I think it was originally part 611080. If its not important i prefer an upgraded one but obviously not if it is not compatible. Engine is 84008622 which falls below the number 84017925 in the book.
Post by Phil Nottingham on Sept 11, 2020 13:49:14 GMT
The dizzies look the same - its only the baseplate that was upgraded and different (cheaper) points used. I doubt if electronic upgrade is being it will make any difference as the problem on the old baseplate was the points dwell set up
Post by enigmas on Sept 11, 2020 22:45:17 GMT
Hi Phil that's the point (no pun intended) of fitting an electronic module as the dwell period or time the coil charges is set/fixed electronically. It no longer varies cyl to cyl due to the variables of a mechanically operated points system. So the benefits are smoother idle, consistent spark quality and accurate timing from cyl to cyl. And of course this benefits in an overall smoother running, more efficient engine.
