rover3l123
Post by rover3l123 on Dec 13, 2020 0:10:38 GMT
Just an FYI
I recently purchased a set of the original Bakelite type plug caps, leads etc (for originality) from Wadhams. However, the caps are not supplied with the rubber o-rings. I had an old one which I measured at 1 inch inner diameter with a thickness of 1/8th inch. Using these dimensions I was able to source some Viton Fluoroelastomer o-rings of with these dimensions from McMaster Carr which is a supplier over here in the US. I choose Viton for its high temperature and oil resistance capabilities.
