Post by enigmas on May 23, 2021 10:02:35 GMT
My Mk3 Rover P5 Coupe hybrid (P76 engine) started to run roughly during a short trip to visit some friends. The overall drive would have been no more than 20 kms. It's an LPG fueled car and has been for 28 years. So no complaints. It's also a cared for vehicle, but now that it's on club plates it's not used as a daily driver. I usually service it once a year.
Interestingly when I arrived home I gave the engine a quick look over and couldn't really find anything amiss. When placed into Drive and under a load, the engine felt as though it was misfiring. Its usual steady idle felt erratic.
I checked the usual sources that would cause this behaviour, shorting plugs, leads, vacuum leaks, faulty coil, etc. All appeared fine. I then removed the distributor cap to check the distributor terminals. (The ignition system is fully electronic with a locked distributor.) Inspecting it carefully I noted there was a white powdery residue on the internal cap terminals. This white powdery coating seems par for the course for most traditional ignition systems that use a distributor cap. I cleaned the terminals with a mini wire wheel using a dremel tool. Sprayed WD40 into the cap and wiped it clean. Restored the cap to the distributor and fired the engine. It started and ran perfectly.
All I can think of as a cause of the misfire was contamination within the cap causing electrical shorting between the terminals. Wiping the inside of the cap and cleaning the terminals fixed the issue. Although I wiped it clean there was no obvious (to the naked eye) dirt or residue within the cap.
A question for anyone with specific knowledge with regard to high intensity electrical energy/arcing. Does a spinning rotor inside a distributor cause/create conductive debris through terminal erosion or similar process?
