Post by p5andrew on Jul 18, 2021 17:49:59 GMT
Neither the heated rear window or rear fog light switch in my P5B coupe are the originals. I would like to replace them with the correct items. Does anyone have a picture showing the correct style of switch in each case? Also, should the switches be the illuminated type when in the on position?
Post by lagain on Jul 18, 2021 20:11:39 GMT
The fog light switch is plain black, pull/push
The HRW is illuminated and also pull / push
Post by dhb5610 on Jul 18, 2021 20:25:40 GMT
Both from Wadhams or try Dave Green
Post by p5andrew on Jul 18, 2021 20:46:03 GMT
Many thanks both.
I do have a plain black switch but this currently controls the hrw. On my car, the hrw switch is on the left. Is this correct or has it and fog light switch or wiring been swapped over in the past? Also, what colour should the hrw switch illumination be? Mine has at some point lost the coloured insert.
Post by dhb5610 on Jul 18, 2021 20:59:30 GMT
Insert yellow
Post by Phil Nottingham on Jul 19, 2021 4:58:14 GMT
Post by dhb5610 on Jul 19, 2021 10:05:01 GMT
I got one from Wadhams
Post by p5andrew on Jul 19, 2021 15:36:33 GMT
Many thanks folks. I have found what appears to be the correct NOS HRW switch on Ebay and have placed an order. It will be good to have the switch details correct. On to the next job!
Post by Ken Nelson on Jul 20, 2021 23:36:37 GMT
Here is a picture of my LHD P5 Coupe with dash partially disassembled. The rear window heater switch is below and right of steering column. The cigar lighter is to the right of that. The insert in the rear switch lights up when on, and I'm sure it originally was white. Attachments:
Post by Phil Nottingham on Jul 21, 2021 20:51:00 GMT
P5s had them as an after thought bracket but same Lucas switch. A rare expensive option then
