gannycat
Hello Phil,
Post by gannycat on Feb 2, 2022 19:36:50 GMT
Hi,
Bought a carburettor kit and took it to an expert for fitting. When the work was done fitted to car but unable to start. Found a very informative article in this months Take Five so started to follow Ken Nelson's step by step advice.
First problem , no 1/18th hole in the butterfly valve. Oh Dear, now what do I do? Ah, I know replace the old one with the hole. All I have to do is to take out the new Butterfly and replace. This is going to be simple even for me! I notice that the two screws holding the Butterfly have been cut through to ensure they do not come loose. Everything fine so far. Here I go with the pliers and try straightening the end of the screw which has been cut through and slightly bent. Snap! both ends broken off, now the unscrew. I cant unscrew the screws and I have a very limited area to work with. Dare not put too much pressure on the screws which do seem rather soft. I imagine they were supplied with the kit.
If this sounds rather basic for an engineer it certainly isn't for me. I know I have to remove the screws but what is the easiest way?
I think I could very easily damage things if I am not careful.
Any advice would be most welcome.
Tony
Post by djm16 on Feb 3, 2022 1:24:06 GMT
If the heads break off the screws, you should still be able to remove the butterfly. You should then be able to grip the screw stub with a small pair of mole grips.
gannycat
Hello Phil,
Post by gannycat on Feb 3, 2022 23:33:32 GMT
Thank you for your advice I shall continue.
Post by enigmas on Feb 4, 2022 12:23:00 GMT
Why not simply drill an 1/8" hole in the new butterfly whilst it's in situ. Use a small pilot drill first then incrementally increase it's diameter in two or three stages.
gannycat
Hello Phil,
Post by gannycat on Feb 4, 2022 13:17:43 GMT
Yes I shall proceed with the drilling option. Thank you.
Tony
Post by Ken Nelson on Feb 4, 2022 14:58:01 GMT
That's exactly what I did to my butterfly. It's easy to drill a 1/8" hole in the lower half, and position is not overly critical.
