Post by Adrian on Feb 25, 2005 19:53:42 GMT
Author: adrian Date: 2/24/2005 7:52 pm EDT I am about to purchase an engine crane could anyone tell me the approximate weight of a 3.0 litre motor complete with borg warner dg fitted?
It states in my manual that it is impossible to remove the transmission without taking engine out. Is this true?
Post by Phil Nottingham on Feb 25, 2005 19:55:25 GMT
The engine and DG box must be removed together unless you want to butcher the bodywork or you can lift the body from the subframe and roll the subframe out. The combined weight is very heavy and the front of the car will lift by at least 6" when the weight is off so you also need a good lift height. I have a Clarke Long Reach Crane which lifts 1 metric tonne easily on minimum extension but I think you need a minimum of 600lbs dead load to be safe
Post by stantondavies on Feb 25, 2005 20:02:07 GMT
Rolling the sub-frame out would be my choice if possible.
Glad to see you are still around Phil. You have been conspicuous by your absence. Been away somewhere nice?
Post by Phil Nottingham on Feb 25, 2005 20:21:44 GMT
;D Nice of you to say so. Not been away Have been watching the world go by and working on my own cars thus letting someone else have their say for change
