Post by Ken Nelson on Nov 19, 2005 17:42:44 GMT
Hi Phil and all; I imagine this is a common problem, but my 3 litre steering box leaks fluid from the bottom seal. I swapped bottom castings with another spare and that stopped it for awhile, but now is back again. Any suggestions? Ken
Post by Phil Nottingham on Nov 19, 2005 18:00:42 GMT
Your are right it is a very common problem - there is another thread on this matter at the moment.
The seal design has been cahnged several times to cure it.
Higher pressures when the oil is cold makes it worse.
You can try additive to give a temporary cure they do actually work
