Post by Deleted on Dec 26, 2007 13:50:00 GMT
hi all,hope your all enjoying the break! has anybody had any experience balancing twin carbs with the gunsons carbalancer? any advice would be good before i give it ago...cheers matt
Post by p5tgc on Dec 26, 2007 15:09:03 GMT
It works, but it is a fiddle, especially when the carbs are not side by side. You have to move the metering plate from carb to carb without disturbing the setting or dislodging the plastic pipes, but it does work and is better than the "hose in the ear" method.
Post by Phil Nottingham on Dec 26, 2007 15:45:49 GMT
I use one of these too - I do think they are worthwhile
Post by Deleted on Jan 7, 2008 14:22:52 GMT
I have a Crypton Synchro-Check flow meter that I use with my Volvo 122S rally car's SU's and have found that the mark one earole is just as good!
