Post by Deleted on Mar 14, 2008 20:00:58 GMT
I have a problem with front end shake in my Mk III -67. The shake start at 100 km/h (60 mph) and increase with higher speed. The engine mounts is new, the shock absorber is quite new (yellow spax). I recently adjusted down the front suspension,(It was set in the highest position) I think the problem got worse after I lowered the suspension. Is my subframe loose ? or is it anything else ?
Regards
Lars
Post by Phil Nottingham on Mar 14, 2008 22:21:26 GMT
One or more of the rubber mounts may have collapsed - if you can rubber its usually a sign of softening (SEARCH). Out of balance wheeels? Slack ball joints. Distorted wheel? The suspension rubber bushes also can have softened.
Post by enigmas on Mar 15, 2008 0:13:55 GMT
Lars, lowering the front suspension does not cause out of balance situations. Take a good look at your cars unversal joints and drive shaft assembly, especially the centre bearing section. You mention that the problem pre-existed?
Post by Deleted on Mar 15, 2008 8:12:35 GMT
Thanks
I will try to sort it out. I have to avoid roads with a speed limit over 90 km/h. Most road in Sweden have a speed limit of 90, it is only our motor ways that have 110.
Regards
Lars
