Post by Deleted on Jan 5, 2005 21:09:36 GMT
Post by Deleted on Jan 5, 2005 21:14:26 GMT
Post by David on Jan 6, 2005 9:23:56 GMT
Not sure what you've done, but I would suggest anyone putting pics on the site ALWAYS click the 'Preview' button first, so you can see if everyting is ok before your post it. It could be your file name/ I noticed you have the following as a filename: ROVERP5/scan.jpg.
Post by glennr on Jan 7, 2005 18:57:50 GMT
Hi Mark To resize your photo's. On windows picture and fax viewer where you see your picture click the second button from the right. It says when you put the mouse over it "closes the program and opens the image for editing" This put's you into PAINT. Click on the image button. Click on stretch and skew. Then in the percentage boxes put for example 50% Horizontal, 50% Vertical. Click OK. You can reduce the size as much as you like. Then save as. It is now saved as that size. I hope this helps. GlennR
