Post by Deleted on Nov 6, 2005 21:28:02 GMT
Would appreciate a bit of help in solving a problem with my 1964 Mk 11 saloon. The brake lights only operate with a huge amount of pedal pressure. Is there any means of adjustment to ensure that they come on with normal pedal pressure, or is there a fault with the switch? Many thanks! David
Post by Phil Nottingham on Nov 6, 2005 21:56:20 GMT
It sounds like the brake light switch has failed - it screws into the T Junction near the brake pulleys in the engine compartment. They are not adjustable or serviceable
Wadhams sells them but there are two types one with a taper thread and one with a straight thread- they are not interchangeable so check which one yours is before ordering.
If you are quick you will not need to bleed the brakes
Post by Deleted on Nov 7, 2005 11:39:18 GMT
Many thanks for this, Phil - is there anything you don't know about these cars? Best wishes, David
Post by Phil Nottingham on Nov 7, 2005 17:03:04 GMT
Thanks - and yes
