Post by Deleted on Feb 7, 2006 10:57:07 GMT
Hi there, i have the oppertunity to buy a new wiring loom for my 68 P5B Coupe but the loom is for a P5B Saloon, i know the coupe has more guages but the 3.5 litre suppliment for the manual says that the wiring diagram is common to all models. Do the looms on the saloons have the wires for the extra guages etc, but they are just not connected up?
Thanks for your help, it really is appreciated - M.Pritchard.
Post by p5tgc on Feb 7, 2006 11:40:39 GMT
Whilst logic would suggest that the wiring looms would be common to both body styles, a check of the parts book shows that Rover had main looms with different part numbers for saloons and coupes, up to B suffix, up to C suffix and thiefproof coil variants!
The body harness is also shown with different part numbers for saloon or coupe.
I would suggest that a coupe loom could be used in a saloon, but not vice versa. The saloon looms would probably not have the additional wires for the extra guage sensors, under bonnet lamps, and rear cigar lighter.
Post by Deleted on Feb 7, 2006 12:35:12 GMT
Hhmmm, as i had feared, it seems like i'm gonna have to pass on this item... unfortunate as i am just beginning to map my old loom in order to make a new one. Probably a good thing in the long run as i intend to use LED's in the dash etc instead of bulbs and a modern fuse box etc. The old cotton braid wiring is a bit obsolete now also, the new stuff has the cotton over the top of the plastic insulation - much better.
Post by David on Feb 7, 2006 14:33:12 GMT
If you are not buying it any chance of letting other saloon owners know?
Post by Deleted on Feb 7, 2006 16:39:03 GMT
Wiring harness can be made by Autosparks of Sandiacre 0115-949-7211 or check out their website (search for Autosparks).
Post by Phil Nottingham on Feb 7, 2006 23:16:01 GMT
They were model & year specific looms but all can be easily modified to suit the particular car.
You are quite right getting rid if the the fabric insulated stuff as it becomes a fire hazard when it starts to crack & fray
Some of the cabling is really heavy and the modern lightweight high current stuff willl be more suitable.
Do not forget to renew the main light switch and wire via a relay
Post by Deleted on Feb 8, 2006 10:58:26 GMT
Saloon wiring loom for sale on ebay right now. 4 hours to go though, Item number: 4609573812
Good Luck
