Post by Deleted on Feb 27, 2006 9:45:28 GMT
I found this on the web. I hope the owner does not get annoyed.
BROWN Battery circuit. From battery or starter switch to ammeter or control box and (with compensated voltage control) feeding lighting and ignition switches (and radio, when fitted) from control box terminal. Also, from starter switch to electric clock, inspection sockets and battery auxiliaries fuse (from which are fed electric horns, cigar lighter, interior lights, etc.).
YELLOW Generator circuit. From generator terminal to corresponding control box terminal and to ignition warning light.
WHITE Ignition circuit and all requirements essential when ignition is switched on but which do not require fusing, e.g., electric fuel pump, starter solenoid switch, etc.
GREEN Auxiliary circuits fed through ignition switch and protected by the ignition auxiliaries fuse, e.g., stop lamp, fuel gauge, direction indicators, windscreen wipers, etc.
BLUE Headlamp circuits. Fed through terminal on lighting switch.
RED Side and tail lamp circuits. Fed from terminal on lighting switch. Included in these circuits are fog lamps, panel lights and other lamps required only when the side lamps are in use.
BLACK Earth circuits. If a component is not internally earthed, a cable must be taken to a good earthing point on the chassis.
Hopefully, the above information, combined with a proper wiring diagram for your car, will help turn that multi-colored mass of spaghetti into an understandable wiring system. Don't get discouraged; Lucas really did make an effort to use logic in their wiring.
