Post by Multi-Tech on Jan 8, 2007 12:23:39 GMT
Went and checked on the car yesterday, started first time (which it always does) but after reading about the fires in a different tread i checked all my wiring.
All seems to be fine but on checking, my side lights don't work on the N/S (front or rear) but if i put dip beam on everything works fine.
Would i be right in thinking it maybe the connections? or a switch?
Wanted to get some input before i start taking to many things apart to find the fault
Post by harvey on Jan 8, 2007 16:03:57 GMT
Sounds like you've switched on the park lights rather than the sidelights.
Post by stantondavies on Jan 8, 2007 21:26:34 GMT
To elaborate in case you re unfamiliar with the switches: Turn the sidelight switch one way and you have the sidelights on, turn the same switch the OTHER way and you get the parking lights, ie the O/S sidelights ONLY.
Post by Multi-Tech on Jan 8, 2007 21:57:35 GMT
O that simple thats what happens when you never take you P5 out in the dark. I will have a look at the weekend to see if thats what i was doing
Post by Deleted on Apr 19, 2007 10:21:14 GMT
How do you change the parking lights over to continental driving?
Post by stantondavies on Apr 19, 2007 10:41:17 GMT
Change over the Red and Red/white connections on the switch?
Post by Phil Nottingham on Apr 19, 2007 16:23:26 GMT
This will only work as its the other terminal to use
