Post by Deleted on Apr 18, 2007 16:28:49 GMT
Blimey, those new-car-tinted specs are slipping off already and I've only had the car three days. (Mk 11c 3 litre)
Does anyone know the quick fix for whatever is causing my indicators, fuel and temp gauges to be dead. Only happened yesterday, and everything else still works.
If the same thing had happened in my Series 3 Landrover, I'd know that I'd dislodged one of the fuses under the steering column with my knee - must get a cover for that fuse box someday..
Back to the P5: have checked fuses I can see on bulkhead - one box of four and two other singles but all are fine.
Any ideas, please?
Thanks
Post by Phil Nottingham on Apr 18, 2007 17:27:55 GMT
The fuse box is open to the elements somewhat and connections become tarnished - try cleaning these up.
Post by Deleted on Apr 19, 2007 15:40:42 GMT
Thanks Phil - I'll try that tonight
Post by stantondavies on Apr 19, 2007 19:29:44 GMT
Is it just the warning lights or are the indicators not working as well?
Post by Deleted on Apr 19, 2007 20:51:46 GMT
Indicators (+warning lights), brake lights, fuel gauge, temp gauge.
Spent ages working through circuit diagrams in the workshop manual, then discovering that the car's been part re-wired at some stage in recent past. The workshop manual seems to indicate that it's the fuse in position 3-4 which controls all these functions, but have checked all fuses and cleaned contacts and not cured fault.
And yet still I love the car like no other.
Post by stantondavies on Apr 19, 2007 21:12:17 GMT
Check the wiring at the indicator unit itself. Is the screenwasher working? Everything you mention should go through fuse 3-4. Have you checked the fuse with a test lamp - it may look OK but the caps can be suspect.
Jos
Post by Jos on Sept 26, 2021 15:41:53 GMT
I need somebody's help I am afraid. Last week suddenly the indicators, braking lights, fuel gauge and temp. gauge (and the Hollandia electric sunroof) stopped working in my saloon.
This afternoon I cleaned all the connections and sockets at the fusebox, measured the fuses with a multimeter, put everything in contact fluid after cleaning, no success.
Checked underneath the dashboard, no irregularities as far as I could see.
Does anyone has a clue what the cause could be? The problem in this thread sounds pretty familiar, which is why I put my question in this older discussion.
Post by dmaxwell on Sept 27, 2021 12:59:17 GMT
Could possibly be the voltage stabilizer? Have you checked the voltage at the various parts that don't work? That could help.
David California
Jos
Post by Jos on Sept 27, 2021 18:04:07 GMT
Thx David, I will check that too.
Post by lagain on Sept 27, 2021 19:35:00 GMT
Does the sun roof have an independent fuse, that may have affected the others.
Otherwise check the earths. The P5 uses the body for earthing and it can cause problems.
