Post by lencottam on Jan 10, 2008 14:09:51 GMT
Or SHOULD THE SUBJECT BE- BLEEDING BRAKES!!! I am re -bleeding my brakes,as I found a slight leak at one of the flexi pipes ,on the front.When I open the bleed screw,and the pedal is pushed down I am surprised how much resistance there is .The screw hole is clear,but on other cars ,when a bleed screw is opened there is usually very little pedal resistance.The flexi pipe is clear as well .Is this normal on a P5b .Before any one says, I dont think its an RG MOD!!!!!
Post by p5tgc on Jan 10, 2008 14:44:03 GMT
Don't seem right to me, is this resistance the same when bleeding at all 4 bleed points?
Post by Deleted on Jan 10, 2008 14:48:11 GMT
Is the flexible hose an old one? If so, it may be blocked internally and so needs to be renewed.
Post by Kev on Jan 10, 2008 16:24:12 GMT
Sounds like the internal rubber tube has collapsed,it's happened a few times to other members and once to me.
E bay normally have a set listed for about £38.00.
Big Kev.
