Post by dorsetflyer on Jan 17, 2005 16:15:36 GMT
OIL FILTERS This list below contains alt numbers for 3.5V8 oil filter. FRAM PH10 FRAM PH25 TJF FB5402 LUCAS CF537 LUCAS CF703 UNIPART GFE145 COOPER Z15A The above list has been taken from past posts on the old site.
Post by Phil Nottingham on Jan 17, 2005 19:36:37 GMT
Crosland is 313
The PH10 is the larger P6 type which has a higher filtration area but is longer although fits easily.
Do not forget that any Land Rover Dealer will supply these very cheaply
Post by guitardave on Jan 25, 2005 17:25:45 GMT
Is there a similar list for the fuel filters?
Post by dorsetflyer on Jan 25, 2005 20:13:15 GMT
I'm not aware of a list of fuel filter numbers.
The part no. for the fuel filter is
Unipart GFE 7004
The same part is used on a landrover but I cannot remember the number. If you get the Unipart version it very often comes in Landrover packaging.
Hope this helps.
