Post by Gianni on Aug 18, 2006 5:46:55 GMT
Blush with embarrassment!! after checking everywhere for problems and ultimately suspecting the new booster, a wise suggestion from the forum (thanks Phil) to check the pedal travel revealed not an adjustment problem but a displacement of the rod going into mastercylinder such that it was offcenter pushing on a rim allowing forward movement but insufficient return to allow the mastercylinder to drain back! all is clearly not as it should be and I will need to investigate further but the brakes at least work now! (as opposed to not being able to stop working!)
Post by Phil Nottingham on Aug 18, 2006 15:51:05 GMT
Well at least your linings/pads should be well bedded in now!!!
