Post by johnwp5bcoupe on Oct 8, 2007 8:46:02 GMT
Have you checked the servo tank and associated pipework for leaks under the driver side wing They are sometimes porous Also servo for leaks
Post by Deleted on Oct 9, 2007 6:51:34 GMT
Its fixed now. That was years ago and the manifold was distorted. Plenty of gasket cement solved it. I was just pointing out a possible fault. If i dropped oil on the joint it was sucked in. The guy who tuned it had seen it happen before.
Post by Deleted on Oct 9, 2007 7:43:23 GMT
ok thanks for that. never come across it on a rover v8 but the stag was quite prone!!
Post by Phil Nottingham on Oct 9, 2007 16:23:20 GMT
Actually these manifolds can distort, its more likely to be careless fitting of the gasket that causes leaks
