Post by park01 on Mar 2, 2005 20:23:22 GMT
were does the wiring for the rear wing side repeater come through the inter wing panel to connect to the loom. (Mine as a new inner wing panel fitted).
many thanks karl
Post by Deleted on Mar 2, 2005 20:30:06 GMT
???Are you looking for the cables or do you want to know where to drill the hole for them in the correct place?
I can provide the dimensions but not tonight as its cold and dark out there
Post by park01 on Mar 2, 2005 20:36:41 GMT
Hi Want to know where to drill the hole in the inner rear wing panel. (Is it the same both sides) No rush. Thanks Karl
Post by Deleted on Mar 3, 2005 17:25:00 GMT
;DBoth sides being the same, looking inside the boot the holes are 8.25" down from the top of the rear toneau panel and 2" inwards from the rear light pressing.
The measurement is not however critical
Post by Smallfry on Mar 4, 2005 22:46:50 GMT
It is if the drilled hole doesn't end up under the trim strip !
Post by Deleted on Mar 4, 2005 22:49:36 GMT
???What trim strip
Post by park01 on Mar 8, 2005 12:27:49 GMT
Thanks Karl
