Post by Deleted on Mar 17, 2005 17:34:46 GMT
Now what? I hab just cleaned out the heater and driven off to the nearest bottle bank when I went to restart it all I got was a click. The indicator lights go out as does the handbrake light. This happens in any gear selector position. I am used to pushing the lever forwards to get a start but it is not this. It is not the battery either.
Post by dorsetflyer on Mar 17, 2005 19:56:38 GMT
Sounds like your starter motor has jammed.
Post by Deleted on Mar 17, 2005 21:33:03 GMT
Ensure all connexiond are good on the motor plus all earth straps eg batter to car boot and subframe/engine/body.
The solenoid could have failed or jammed its esy to test this by bridging the terminals on the solenoid but watch out for sparks
Post by Smallfry on Mar 18, 2005 1:04:55 GMT
Yup as T Bar says......I would suspect poor or dirty connections in the main battery lead, probably at the solenoid end. Next, the small connections on the solenoid, Don't forget to check the engine earth strap if that fails !
Let us know how you got on ?
Post by Deleted on Mar 18, 2005 9:17:47 GMT
It was the inhibitor switch. One of the leads had fallen off. I never thought it was the solenoid as it clicked in all selector positions. Thanks for your help.
