Post by Deleted on Aug 25, 2008 21:13:34 GMT
I have just bought a mk II (suffix a) manual with overdrive. In the workshop manual section Y, they recommend engine oil for the overdrive (20W single grade). Anyone that have any advise on oil ? I normally use 20W-50 in the 3 litre engine, is it wise to use the same oil in the overdrive ? I know that Rover changed the oil recommendation from EP90 to SAE 20 in June 1963.
Regards
Lars
Post by Phil Nottingham on Aug 25, 2008 21:19:09 GMT
20/50 is Ok - EP90 was used in earlier overdrives as it they shared the same oil as the gearbox. EP90 is approx the same as SAE 40
Post by Deleted on Aug 25, 2008 21:21:34 GMT
Thanks Phil
Regards
Lars
