jimsbruv
1963 3 litre coupe auto
Post by jimsbruv on Sept 6, 2008 21:06:09 GMT
Hi Guys Can anyone recomend the best place to purchase carpets for a 3 litre coupe , i have looked on wadhams site and he makes them to order from your original pattens . Thats fine but mine have been in for some years and im fairly confident that they are from a p5b hence they dont fit as the gearbox tunnels are different , mine is an auto by the way so it has the slightley raised section over the gearbox tunnel. The other question is where do you guys purchase you door and screen rubbers from , im terrified about fitting the screen rubbers but it has to be done so it goes to the paint shop at the end of the month!!!!!!!!!
Post by Phil Nottingham on Sept 6, 2008 21:57:07 GMT
I thought Wadhams does carpets for 3 litres as well - phone him. The raised centre section to form a carpeted "tray" fitted to MK2/3's only is not readily reproduced either. A good secondhand one is better - David Green or Ebay when they turn up
As to rubbers (and the new clips) Wadhams or Scotts via David Green. As to fitting do not bother get experts to do this - use SEARCH
Badly fitted rubbers can often be seen as can damaged SS trim stirps
