Post by mcgill on Oct 31, 2008 10:02:40 GMT
i didnt know if to stick this under body or electrical or mech,as it covers all three. apart from the obvious rostyles,shared with jensen,and bumper parts with aston,does anyone know of other parts that are shared to make finding parts easier, like the overiders from a stag or p6 are they the same??ANYTHING
Post by PatMcCoy on Oct 31, 2008 10:14:24 GMT
interior lights MG
Post by johnwp5bcoupe on Oct 31, 2008 11:36:48 GMT
Not Many Jensen wheels are much wider if I remember correctly! overiders not common to any other car, Lockheed Type7 servo used on several cars! I will keep thinking
Post by Phil Nottingham on Oct 31, 2008 12:09:08 GMT
I have made this a sticky. A number of engine and chassis parts are shared with P4 and older Land Rovers, both straight 6's and V8.
Most body and trim are unique (grab handles are P4, as are front layback seats in 3 iLtres) as is steering and suspension and front disk brakes
Virtually all of the Lucas electrics were used on many other cars of the same period
Post by eisdielenbiker on Oct 31, 2008 19:20:24 GMT
A friend of mine has a Triumph Stag. I think the V8 overriders could fit there. Do they ? I just purchased a few screws for the door hinges from a MGB. I guess that doesn't matter. What screws do I need for the lock plates fixed to the D-post ? MGB won't fit. Regards Mark
Post by rovertone on Oct 31, 2008 20:13:05 GMT
I also have a Triumph Stag (not for long term keeps) in addition to my P5B. The overriders are different on the P5B and are 'filled in' on the back whereas the Stag overriders are 'open' on the back. The rubber inserts look the same but Rimmer Bros sell those at £8.50 + VAT so best to stick with Wadhams at £6.50 + VAT! Sorry I don't know what screws you need for lock plates at the moment. Perhaps someone else knows the answer to that one.
Post by Phil Nottingham on Oct 31, 2008 20:19:19 GMT
5/16th" UNF countersunk
Post by Roy of the Rovers on Nov 9, 2008 19:24:22 GMT
P5B underbonnet light covers shared with Range Rovers. Bonnet safety catch-the one that breaks- shared with Moggie Minor. Interior lights shared with MGB?..I think Series 2 jag electric window winders bolt in replacement for saloon winders to give electric windows..
Post by Phil Nottingham on Nov 9, 2008 20:48:06 GMT
The prop shaft joints are the same as the Series 2a & 3 Land Rover type as are the rear brake shoes (Series 2 & 3 LWB only). Front disks/pads are sahere ONLY with the P4 100-95-80-110
3 Litre spark plug covers were used on P4's and Land Rover IOE S1 (6 cyl 2a & 3 to 1980)
Oil filter for the 3 Litre is also Land Rover 6
Post by eisdielenbiker on Nov 10, 2008 8:19:22 GMT
Phil, what does LWB mean ? Mark
Post by Phil Nottingham on Nov 10, 2008 8:37:00 GMT
Long Wheel Base as opposed to Short Wheel Base SWB - as Land Rover's used a 4 cylinder IOE engine from the P3 for while and which was also simlilar to the P4 60 + plus the 26 Six IOE was used in LR's from 1967-1980 some engine bits and gaskets wil fit the P5 3 Litre.
Also the Cold start "Otter switch" used on pre- AED V8's and all 3 Litres.
The front side light bulb holder can be rebuilt using tye common Lucas glass Domed/flat bublholdersfor the larger SCC BA15 bulbs
Post by indianbob on Aug 25, 2009 21:42:33 GMT
which other Rovers used the same gearbox as mk 1 with overdrive?
Post by Phil Nottingham on Aug 25, 2009 22:43:07 GMT
Try search - posted only a couple of months ago
None - apart from M1a and P4. The outside cases differed though
Some or of the internals however may well fit from P4's of the same period - they came with or without overdrive.
The design dates back to the early 1930's and right into the S3 LandRovers (but not in the P6/SD1)
Post by mcgill on Jan 26, 2010 13:16:47 GMT
hand brake linkage end forks.same as series landover.original parts complete at about £3.50
Post by Phil Nottingham on Feb 2, 2010 19:43:31 GMT
Post by Phil Nottingham on Feb 2, 2010 19:47:53 GMT
Not sure whether any of you noticed the Mintex (genwine asbestos ) disk pads on Ebay last week which apart from from fitting P5's (and P4's which was not mentioned) were said to fit Armstrong Siddley Sapphire (not sure whether this included the star as well?) These very fine cars are quite rare and even "better" than P5's so I am not sure that this will make pads any easier to find. Anyway I won the pads for £16 odd and they are just the job ;D
theroveringmember
Post by theroveringmember on Feb 4, 2010 22:22:18 GMT
My father & I were offered a Sapphire once. Can't recall if it was a Star or not. A lovely barn find but we shied away from the amount of work & money it needed throwing at it. At the time we were restoring my P5B. They're very big cars.
Post by mcgill on Jul 22, 2010 17:07:24 GMT
Oil pressure transmitter,optional coupe.V8 LAND ROVER BRITPART 555947,£30 OR CHEAPER
Post by Deleted on Aug 24, 2010 10:52:59 GMT
I have just been quoted 209 euro for this Part number in Berlin are they on Crak Cocane..! Rimmer Brothers €48,15 inc VAT. www.rimmerbros.co.ukAny one know witch one is the best..Geting Confused now..!
Post by mcgill on Aug 24, 2010 11:14:11 GMT
I have just been quoted 209 euro for this Part in Berlin are they on Crak Cocane..! That 209 euros is correct for that part number ,but is for the ORIGINAL oem part which is no longer made,(there was a new one on ebay last week for about 60 euros) ask the for the britpart version with same code,try a landrover parts place of failing that im sure jr wadhams should do one for 70,depending on exchange rates.. If you still cannot get one,pm me and ill get you one as above in picture sent over via ebay and paypal.if that helps
Post by Deleted on Aug 24, 2010 11:30:41 GMT
Thanks mcgill..the one on my p5 is the same as the one you have in the picture it leaks from the Plastcik bit and a lot..I will get back to you if I cant get some sorted Thanks again
Post by p5pete on Feb 24, 2011 11:42:03 GMT
"These very fine cars are quite rare and even "better" than P5's so I am not sure that this will make pads any easier to find."
I hope to have new none asbestos pads for sale in club parts for June Take Five. ;D
Post by Deleted on Feb 24, 2011 19:52:24 GMT
some intermotor numbers
51630 Brake light Switch ->1967 33710 Condenser 22560 Contact Set 22970 Contact Set Lucas 59-60 44880 Distributor Cap 11040 Ignition Coil ->1967 12 Volt 11105 Ignition Coil 50520 Oil Pressure Switch 47560 Rotor Arm 68000 Starter Solenoid 52710 Temperature Transmitter ->1967
trymes
Post by trymes on Nov 21, 2011 0:46:01 GMT
I have been doing dome research on this, and the Land Rover 2.6L engine is apparently a de-stroked 3 Litre engine. It is NOT the same as the earlier P4 2.6 Liter engine. As such, the head gasket fits, and I imagine the pistons and many of the other internal bits would, too.
The oil pressure light sender is also the same as the Land Rover.
Tom
Post by denis23 on May 8, 2012 7:21:19 GMT
Somebody told, that steering rack is the same like Volvo 144, is this true?
