Post by Eric R on Apr 22, 2009 7:31:41 GMT
The only thing to spoil my enjoyment is the heavy steering. Can anyone suggest means/cost of retro-fit power assist?
Post by Warwick on Apr 22, 2009 9:14:57 GMT
If you don't have power steering Eric, and you have to adapt something else, don't bother with the later model steering box - go straight for the Volvo box.
As Phil might say - try Search set for a million days.
Post by Eric R on Apr 22, 2009 10:33:11 GMT
so do you mean replace the Rover steering box with a Volvo one? Hmm! which model then! The one from my V70 wont do for sure!
Post by Phil Nottingham on Apr 22, 2009 18:40:06 GMT
Just fit the set up from a later car - David Green will supply - you will need the dynamo/pump set up of the 3 litres and pipes/hoses if you do not buy new ones and check the subframe has the alternative powerbox fixings as early ones did not. The catual box was same throughout as wsa the basic pump. The column is the same too.
Rover did a kit to convert early Saloon cars (P/s was optional extra till 1964!) as with disk brake conversions
Post by Warwick on Apr 23, 2009 2:17:02 GMT
