Post by Eric R on Sept 21, 2009 14:53:04 GMT
engine runs well normally but hesitates and mis-fires on quick acceleration or as soon as under load - then the car bucks like a stallion! Carburetter professionally restored, new rotor arm and distributor cap previously installed, points spot-on all to no avail. If i replaced all the leads and plugs, are there modern replacements like carbon leads which will perform any better? If the engine "breathing" becomes blocked is it sufficient to remove the oil filler and rear breather caps to clean the gauze areas, and if so, how best achieved - wash out in petrol and wire-brush?
Post by Phil Nottingham on Sept 21, 2009 21:43:13 GMT
Cleaning the breathers with paraffin (not petrol!) is the accepted way. This should not cause missfiring on a old 3 Litre unless you have terminal piston/bore problems.
Bad missfiring under load is either burnt exahust valve usually no 5 or 6 or weak mixture caused by air leak
Check dizzy earth lead is not shorting when base plate moves vacuum advance. I hope teh condensor was replaced too!
Post by Eric R on Sept 24, 2009 15:11:01 GMT
There appears to be 100s of condensors - do we have part number? and what about replacing leads - have they become specialist parts?
Post by Phil Nottingham on Sept 24, 2009 15:51:35 GMT
It depends what Dizzy you have DMBZ6? The leads and be made up or bought made or off Ebay from time to time as OE. To make your own see www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.phpEven if you have a later dizzy fitted the 25D6 its condensor will fit and these aere used on the really common 25D4 dizzy for Mini's Hillmans etc and Halfords stock them for a couple of £'s just do not mention "P4" just ask for a 1978 Mini 1100 with Lucas dizzy
Post by Eric R on Sept 27, 2009 9:02:28 GMT
Users manual states dizzy to be DMBZ.6A. Will need to verify this and then check the other items you mention Phil.
Post by Phil Nottingham on Sept 27, 2009 10:17:01 GMT
It will say type on it - and is standard fit for the time - later ones (which are not as good!) will fit though and are often substituted
The later type has a plastic slide out LT terminal in its side
