Post by Deleted on Jan 24, 2010 8:10:11 GMT
greetings to all. beginning the restoration of a P5 3.0L. When you can pondre photos. maybe can count on your help. my English is very bad , I'm from Valencia, Spain. and the car is registered in Madrid, Spain left hand drive. should need parts and good advice. and patience and work je.je.je. well, virtual beers for everyone Attachments:
Post by Kev on Jan 24, 2010 8:59:56 GMT
Welcome Marcelo, it's good to hear another car is to be saved.I must say it does look a bit of a "project".... it may drive you to drink! There is a wealth of information to be found on this website. Good Luck. Big Kev.
Post by Phil Nottingham on Jan 24, 2010 11:11:58 GMT
Welcome Marcelo but do not worry too much about your English we are that good at it either!
Post in Spanish if not sure and someone will transate pictures tell far more
Have you any history to the car - its a Mk3 Saloon straight 6, is it auto or manual?
miguel
Post by miguel on Jan 24, 2010 13:13:18 GMT
Marcelo, wellcome. You'll have no problems with the restoration. This forum has many experts that can help. Not me, I'm one of those that takes more than it gives. If you have any problems with the language I can also help, but it looks like you wont need that. I see you have a long job ahead of you, but the car deserves it. There are a lot of spare parts, mostly in England, and on ebay motors you'll find a lot more.
More photos would be nice. Miguel
Post by norvin on Jan 24, 2010 13:37:39 GMT
Hi Marcelo, your car looks like it will need plenty of parts and work so good luck, we will all help you as much as we can, but post more photos.
Post by glennr on Jan 24, 2010 15:20:48 GMT
greetings to all. beginning the restoration of a P5 3.0L. When you can pondre photos. maybe can count on your help. my English is very bad , I'm from Valencia, Spain. and the car is registered in Madrid, Spain left hand drive. should need parts and good advice. and patience and work je.je.je. well, virtual beers for everyone Hola Marcelllo, no te preocupes por la traducción. Usted puede utilizar "herramientas de traducción" en la Internet. También estoy muy orgulloso de tener a mi hija para ir a la Universidad de Nottingham para leer de Estudios Hispánicos (español y portugués). Así que se puede traducir sus e-mails si es necesario. Hello Marcelllo, do not worry about the translation. You can use "translation tools" off the Internet. I am also very proud to have my daughter go to Nottingham University to read Spanish and Portuguese. (Hispanic Studies) So she can translate your e-mail if necessary.
Post by Deleted on Jan 24, 2010 20:15:41 GMT
Muchas gracias por tan buena acogida. si el coche no deja nada de lo que recogerla el viernes, grúa deberán ser transportados en 180 kilometros. el cambio es automático. esta posición durante 20 años, se rompió un manguito de la calefacción y la junta se rompió, el resto de la mecánica en ese momento estaba en perfectas condiciones. dentro de una semana tendrán un diagnóstico más preciso de lo que necesita para funcionar de nuevo. He restaurado algunas de Land Rover (me gusta el Land Rover), Serie II bis-seriesIII.Rangerover v8 carburadores de mi linda y un niño Rangerover 300 Tdi 1995 la última vez que la unidad de todos los días de fiesta y es la única que conserva el V8 lleva mi hermano. más información cuando le dices a ella. Attachments:
Post by Deleted on Jan 24, 2010 20:19:35 GMT
thank you very much for such a good WELCOME. if the car does not fail anything I pick it up on Friday, crane must be transported in 180km. the change is automatic. this stand for 20 years, broke a sleeve of the heating and the gasket broke, the rest of the mechanics at that time was in perfect condition. within a week will have a more accurate diagnosis of what needs to function again. I have restored some land rover (I really like the Land Rover), Series IIa-seriesIII.Rangerover v8 carburetors and my pretty boy one Rangerover 300 Tdi 1995 the last I drive all the holidays and is the only one keeping the leads v8 my brother. more information when you tell it. Attachments:
Post by Phil Nottingham on Jan 24, 2010 22:31:11 GMT
Fellow Rover nut then - we have a 1958 S2 and 1973 S3 LR's as well as P4
Post by glennr on Jan 24, 2010 22:44:04 GMT
Bueno Cheers ;D virtual beers for everyone
Post by Deleted on Jan 30, 2010 9:31:54 GMT
'm defrauding. the car is in bad shape. to restore the whole engine. interior upholstery torn. restoration that requires a 100% has rust in many places.
I can not invest so much, so much money.
thanks for everything, but the p5 and I travel together.
but if it persists in driving British cars. my land rover. (this week I RECEIVED paddock material to put on RR 300 Tdi verge of 1995.)
GREETINGS FROM VALENCIA
siento defraudaros. el coche esta en mal estado. todo el motor para restaurar. tapiceria interior destrozada. la restauracion que requiere es al 100% tiene oxido en muchos sitios.
no puedo invertir tanto,tanto,tanto, dinero.
gracias por todo ,pero el p5 y yo no viajaremos juntos.
pero si continuare conduciendo coches ingleses. mi land rover. (esta semana he recivido material de paddock para poner apunto el RR 300 tdi del 1995.)
SALUDOS DESDE VALENCI
Post by norvin on Jan 30, 2010 15:51:58 GMT
Sorry about your car Marcelo, it needs a lot of work.
Post by glennr on Jan 30, 2010 16:00:27 GMT
Marcelo, you have made the right descision
