rcoups
Post by rcoups on Jan 27, 2010 21:14:36 GMT
Having my dynamo refurbed, new bearings, brushes etc at a cost of £60 - £70. Will be like new so I was told by the auto electrician, then back on the car and then a few minor jobs to do then MOT time. Hope to see some of you at shows
Post by Phil Nottingham on Jan 27, 2010 22:12:06 GMT
well done - it should last another 45 odd years
rcoups
Post by rcoups on Feb 1, 2010 18:32:38 GMT
got the dynamo back and it is looking good, just got to put it on the car. When I get the car started it seems to have gone on strike, went to take her out of the garage so I could fit the dynamo, she started up fine then halfway out she stopped and refused to start had to push her back in
Post by Phil Nottingham on Feb 1, 2010 19:27:34 GMT
Too cold - but more likely fuel pump stick - another recon due! Give it knock but it will keep doing it at the most awkward and embarrassing times
rcoups
Post by rcoups on Feb 1, 2010 20:30:06 GMT
refurbished the pump with electronics from bodens, not unless a wire has come loose, will have to check that out
