Post by mcgill on Feb 21, 2010 9:48:09 GMT
Well as with the rest of the car,if it unbolts,change it,restore it ,powder coat it.......or that nice tin of hammerite smooth.. The engines out,ive had a clean up,but the loom ,well the cloth braided wires really are pretty hard to distinguish. Before i wash awaY the colour,anyone know of anything that brings them up? (before i end up renewing these as well). ITS so i can wire stuff back up,and not so much it,look better..............or so i keep telling myself!!! thanks all..........
Post by Phil Nottingham on Feb 21, 2010 10:36:46 GMT
Bio washing powder will clean the palstic and textile coverings but if the textile is partially rotted it will be be hardly worthwhile when it goes up in flames on reconnection
Post by norvin on Feb 21, 2010 12:04:58 GMT
You can buy proper loom tape from vehicle wiring, so if the wiring is sound then this tape makes a realy good job of it.
Post by Phil Nottingham on Feb 21, 2010 13:16:56 GMT
Beware usingh ordinary PVC electric tape as the glue on this will soften with underbonnet heat and oil fumes and it will come unstuck leaving a stick black mess
Post by norvin on Feb 21, 2010 17:14:25 GMT
Yes you are right, but this stuff is proper loom tape that will stretch tight around the cables it has no glue on it, so you can just put a spot of glue on the end if it needs it.
Post by Phil Nottingham on Feb 21, 2010 17:45:34 GMT
I know - I have used it for 40 years! (and Vehicle Wiring products which is just down the road)
When winding it on it is important to keep under tension and overlap it properly.
Looking at the pictures I would be relunctant to retape some of that old fabric covered cable though.
I can recommend Autosparks for a new period loom - that too is just down the road - I have no financial or social connection with either firm either!
theroveringmember
Post by theroveringmember on Feb 21, 2010 19:45:54 GMT
I use the plastic pre-formed type of cable tidy. Black & spiralled, it looks very neat & if you add cables you simply unwrap it, add your new wire then re-wrap it again. Not original but very efficient.
Post by glennr on Feb 21, 2010 22:11:03 GMT
Post by eisdielenbiker on Jun 12, 2010 9:46:29 GMT
WD40 is an effective cleaner for non-texiles in engine bay. I like this most as it doesnt promote rust any further like water does. Mark
Post by enigmas on Jul 2, 2010 12:52:58 GMT
Looks like hours of fun McGill!
