rcoups
Post by rcoups on Apr 8, 2010 21:08:00 GMT
I beleive there were 6,000 made so it would be interesting to know how many have survived, I have a 1966 automatic
Post by stantondavies on Apr 9, 2010 17:01:38 GMT
SNAP! So that makes two!
Post by Deleted on May 17, 2010 23:19:33 GMT
if seven is magnificent... what does that make the three of us mine is also a 66 auto... with colum shift
rcoups
Post by rcoups on Jun 20, 2010 8:31:15 GMT
Looks like we are the 3 muskateers or mark3ateers...lol Are you taking yours to rockingham?
Post by enigmas on Jun 20, 2010 9:41:34 GMT
I've got one too...but its modified a bit.
rcoups
Post by rcoups on Jun 21, 2010 15:46:42 GMT
what mods have you done, I put a lockhead servo on mine but thats all
Post by Deleted on Jun 28, 2010 11:09:19 GMT
Interesting... the servo is off of mine right now, and i'm not looking forwards to rebuilding it, as it doesn't look quite right for some reason.
what's the story with lockheed?
rcoups
Post by rcoups on Jun 28, 2010 12:13:24 GMT
The girling servo I had on mine was full of break fluid, so I had a look on the forums and as far as I could tell the view was that Lockheed servo's were better than the girling. So I fitted a lockheed in place of the girling and it works fine. You have to make some minor alteration for fitting it but there is information here on the forum.
Post by Deleted on Jun 28, 2010 17:09:37 GMT
Interesting...
But i think i'll stick with me Herman Girling hah hah
Post by Deleted on Jun 28, 2010 17:10:30 GMT
Post by stantondavies on Jun 29, 2010 20:47:13 GMT
Looks like one to me.
Post by enigmas on Jun 30, 2010 7:04:57 GMT
Rcoups, I purchased mine in very run down condition and started from there. List of Mods: Leyland P76 4.4 litre V8 (Aussie version of the 3.5 Rover engine) fitted to a Rover Mk3 BW35 case with BW40 internals (Aussie box). Differential centre changed to 2.9:1 ratio and fitted with Mercedes rear disc brakes and Mk 2 Jaguar calipers. Dual fuel (LPG) but currently running full time on gas. Four core aluminium radiator runnning bottom and top thermostats with owner constructed bypass system, twin auxiliary electric cooling fans switched by a thermal switch. Have also retained a mechanical flex fan and fitted air conditioning. Twin circuit brakes (EA Ford fast fill master cyl with booster fitted in left rear side of boot). Twin pipe exhaust system. Cruise control. Engineer certified.
rcoups
Post by rcoups on Jun 30, 2010 13:06:34 GMT
sounds interesting enigmas, so basically a rebuild with extra's
Post by Deleted on Jul 9, 2010 18:50:21 GMT
OK....... which one of us has the oldest mk3? ? mine was registered on may 1st 1966... and it has to be an early car, as it has the same rear cylinders as the mk1 and mk2... aka, the longer slimmer pistons, which are not the same as the latter ones, / p5b's.
rcoups
Post by rcoups on Jul 11, 2010 18:36:49 GMT
Mine was the 3rd of may, you win javascript:add("%20:P")
rcoups
Post by rcoups on Aug 2, 2010 17:47:22 GMT
Well lads I have found some more mark3's taking our total so far to 8
Post by Deleted on Aug 7, 2010 10:20:41 GMT
Well lads I have found some more mark3's taking our total so far to 8 Yeah... but they need to be on here to officially count. and who's got the oldest one? can any of them beat May 1st 1966? ?
Post by stantondavies on Aug 7, 2010 22:49:54 GMT
Will registered on 1st April 1966 do? Chassis 80000212A.
Post by Phil Nottingham on Aug 8, 2010 6:22:13 GMT
Yes but are we talking about build date or registration date as there were some F Mk3's out there for youngest and E's
rcoups
Post by rcoups on Aug 8, 2010 10:58:58 GMT
mine was the registration date, being a black one i should imagine it was built not long before for special order, I might be wrong about it but usually they are government or mod cars I believe, not unless some one has more information that could put some light on the black coloured cars. Would definately like to know any info on the subject.
Post by Phil Nottingham on Aug 8, 2010 13:10:10 GMT
A lot of black Rovers were for ministry especially the P5B's which tookover from the big Humbers like the Hawk, Super Snipe and Imperial in 1967
Post by Deleted on Aug 10, 2010 20:18:18 GMT
Yes but are we talking about build date or registration date as there were some F Mk3's out there for youngest and E's DUNNO ABOUT F's AND E's MATEY... MY ONE'S A D. THOUGH MINE IS ONE OF THE EARLY ONES, AS ITS GOT THE REAR CYLINDERS FROM THE MK1 AND MK2... LONG SLIM PISTONS AND THREE CLAMPING SCREWS... UNLIKE THE LATTER P5B REAR CYLINDERS, WHICH ONLY HAVE TWO SCREWS AND USE SHORTER, THICKER PISTONS. AND... AND... AND... MY SEATS ARE THE DEEPER, THICKER SET SEATS... TWO LOTS OF TWO... WHICH IS ODD, AS MOST HAD THE BENCH SEATS AT THE BACK
Post by mcgill on Aug 18, 2010 6:30:43 GMT
My son was doing his bit for charity Sunday as a Sea Cadet and came back with pics of this. Is this another one for your list??
rcoups
Post by rcoups on Sept 12, 2010 19:26:27 GMT
My son has just bought a mark3 1966 from the Isle of Man
Post by Deleted on Sept 19, 2010 15:19:23 GMT
I have a MK3... D registration and first registered on the 23rd June 1966. Last on the road in 1987 so it's in a very sorry state!!
