Post by Deleted on Jan 18, 2011 20:09:14 GMT
hi does anyone have a close up photo of the fusebox including cover as the car i've bought has a few wires off and also the cover is missing,or if someone could tell which colours in relation to which fuse position that would be great , thanks in advance tony
Post by Phil Nottingham on Jan 18, 2011 20:17:14 GMT
There is pic on here somewhere use SEARCH!
Post by Deleted on Jan 19, 2011 8:01:03 GMT
thanks for that , not having the fuse box cover i wasn't sure which fuse was which in relation to the wiring diagram, but now i see it , thanks again
Post by stevew on Jan 19, 2011 19:04:37 GMT
Hey zed, have you been to your local p5 meets? great bunch of guy's
Post by Deleted on Jan 19, 2011 20:48:23 GMT
Hey zed, have you been to your local p5 meets? great bunch of guy's no i haven't still have plenty of work to do on car , welding ,brakes, etc. where and when are they held ?
monsieurboz
Now an owner of a gleaming green LHD P5b.
Post by monsieurboz on Oct 12, 2022 10:31:12 GMT
That settles the question I posed on FB (p5 owners group) this morning… the wires downstream of the fusebox were plastic coated from new, which should help the auto electrician find the fault with my headlights.
Post by enigmas on Oct 14, 2022 0:31:11 GMT
Hi Boz, you'll find, if you thoroughly clean all the electrical connections, switches, fuses, bullet connectors to bright contacts and all earth/ground contacts (yes, scratch the paint off at these contact points to bright metal) that the lights and indicators will function as designed.
A Side Note. Given the age of these vehicles now, who has ever bothered to thoroughly clean the contact connections on the large underbonnet fuse box? I'm assuming perhaps 2% of the current owners, but stand to be corrected.
Most electrical issues are due to high resistance on the electrical connections.
Post by Sam Bee on Oct 15, 2022 11:31:06 GMT
Mine, cleaned in my bead-blaster.
Post by johnwp5bcoupe on Oct 15, 2022 13:49:06 GMT
Tomato Ketchup or household Ammonia leave in soak overnight and it will come up like new :-) if you use Ammonia rinse in water straight away :-)
Post by Mike’S-a-loon on Oct 15, 2022 15:06:13 GMT
And if you use tomato ketchup, wipe it off with hot chips.
