Post by glennr on Apr 14, 2011 6:47:40 GMT
Hi all, Patrick in France (whose English is as good as my Russian) is looking for the foam to replace the foam in his old seats. Can anyone (via me) push hin in the right direction for a supplier and what he should ask for
Post by johnwp5bcoupe on Apr 14, 2011 6:56:42 GMT
I will try and help HIN Glenn As you know I did mine and the foam is a difficult one to answer I tried several firm foams used in the domestic upholstery trade which were far to soft! I eventually found a firm white one, it's a case of going to a supplier and finding a suitable one that will do the job problem compounded as he is in France
Post by glennr on Apr 14, 2011 7:04:23 GMT
Merci John.
Post by glennr on May 8, 2011 3:14:49 GMT
I have now sorted the brakes, but the tachometer I do not know how it connects. Can you help me and ask on the forum what is the white wire connected too? and the green wire? In advance, thank you. Attachments:
Post by johnwp5bcoupe on May 8, 2011 5:58:26 GMT
Hi Glenn the green is the +ve feed from switch, the white goes to the ignition ballast it's in series with the ignition coil as it picks up ignition pulses induction wise (not direct), the -ve is the case of the tacho.
Post by glennr on May 8, 2011 6:38:13 GMT
Thank you John .
