rcoups
Post by rcoups on Apr 18, 2011 12:01:25 GMT
Classic Car Voltage Stabilizers Semiconductor voltage stabilizers for classic cars classicstabilizers.webs.com/information.htmGood website for a voltage regulator that controls your guage dials in the car, Ive put one on mine and it works a treat, no more faulty readings from fuel and heatiing gauges
Post by stevew on Apr 18, 2011 17:40:51 GMT
What's the damage ?
Post by Phil Nottingham on Apr 18, 2011 18:19:18 GMT
Seen them at approx £6 - LR users like them!
trymes
Post by trymes on Apr 19, 2011 15:26:55 GMT
For anyone on the other side of the Atlantic, Limey at Bits4Brits (http://bits4brits.net/) sells a solid-state Stabilizer. IIRC, he used to convert the mechanical ones, but a lack of old ones to convert seems to have pushed him to make a new one, which is listed as for Negative Ground only.
His relay kits are excellent for taking the load off of the switches in the dash, too, plus providing brighter lights and a louder horn.
Tom
PS: When did the P5 go to Negative Ground/Earth?
rcoups
Post by rcoups on Apr 19, 2011 16:56:32 GMT
the price is on their website I think its about £8.00
Post by Phil Nottingham on Apr 19, 2011 21:23:36 GMT
From Mk3's onwards but no problem convering unless Rev counter is installed and still works
trymes
Post by trymes on Apr 19, 2011 22:10:10 GMT
Excellent. I know that the Rev Counters for MGBs can be modified if converting, without much effort, or folks like Nisonger or Palo Alto Speedometer will even modify the internals to work electronically if you have a system like EDIS that does not provide a strong enough pulse for the original equipment.
Tom
