Post by Kev on Sept 18, 2011 7:24:37 GMT
Hey they're not bad wheels,mind you i still prefer the Jensen's. Good mod & as you say,you needed the additional space.
Big Kev.
Post by redsunbeam on Oct 9, 2011 12:37:17 GMT
Crossplies, i thought long and hard about this one. There is no way to simply sum it up. I started looking at the pictures from the national and nice as they are, i only looked at four before my interest wandered. They all look the same. I want something different. Its also a challenge for me to see if i can make my ideas work.
Post by Deleted on Oct 9, 2011 14:23:33 GMT
Having owned them both at the same time I just can't wat to see the combination! Its looking good.
Post by redsunbeam on Dec 20, 2011 10:14:10 GMT
Getting there slowly, Brake servo relocated, just need to make up new brake pipes when the engine is out for the last time, Cooling system header tank from a subaru sited, MAF sensor and air filter in place, mods to grill finished. Still need to find a home for the power steering header tank, finish fabricating the exhaust, refit the fuel tank when it comes back from having a sump fabbed and fitted, fit new fuel lines and wire in. Simple.
Post by Kev on Dec 20, 2011 17:38:12 GMT
;D Now that looks brilliant...cor she's gonna sound amazing,well done mate,can't wait to see the finished result. Big Kev.
Post by zaphod on Dec 20, 2011 18:04:47 GMT
Excellent work. I am surprised how well the lump fits. Still miss our Lexus LS400!
Post by cyf on Dec 20, 2011 18:38:30 GMT
That's an impressive job you're making, redsunbeam.
I saw on the pictures that you blinded the holes for the indicators and bumper brackets, and removed all the chrome work. Do you want to do a "chrome free" car? what plan do you have for the interior?
I have a Coupé needing a restoration and I'm thinking of remove all the chromes (including bumpers), put a grille mesh as you did, respray it with an non-standard colour and give it Rover SD1 Vitesse type Wheels. I'll leave original engine and transmission.
I know it would be as costy as a proper restoration, and some members won't understand it but it would be "my" car. I have a P5 Coupé in good shape, and I want another one, different I don't know if i'm understable
Post by enigmas on Dec 20, 2011 21:26:07 GMT
Nice work redsunbeam. Looks like a great fit. Look forward to you firing it up.
As an aside what radiator are you using?
Also consider not mounting it rigidly (as is the original radiator) I found on my conversion that the tanks were being flexed over time (by body movement) and causing irritating 'weeping' leaks between the core and tanks)
Post by redsunbeam on Dec 21, 2011 16:19:17 GMT
Enigmas, The radiator is from a diesel mondeo with twin electric fans from an st220 mondeo. Ive mounted it with the original rubbers the same way ford did in the mondeo. It has a pin through the centre of a large rubber bush that allows it to flex a little in all directions. One thing ive learnt along the way is to imitate the manufacturers ( most of the parts ive used are from other cars rather than universal aftermarket stuff, it tends to be better made and much cheaper ) Their huge R&D budgets must count for something. Having said that, i am using an aftermarket fan controller. Cyf, The interior is remaining as standard looking as i can, its taken an age to get the gear shifter linkage right so that i can use the rover selector with the lexus box. I am having the original speedo converted to electronic so it looks original. Some things like the central locking wont be seen anyway.
Post by enigmas on Dec 22, 2011 0:33:54 GMT
You're doing a great job with the car Redsunbeam. I had a aluminium radiator made at great expense and it's proved to be a constant irritant with small weeping leaks. Your solution with the mondeo radiator is a good one...especially since it's from a diesel.
Mounting radiators rigidly (as per the original) is fraught with trouble if you considering mods like yours.
Post by Warwick on Dec 22, 2011 2:23:56 GMT
An interesting contrast in radiator mounting can be seen between the P5B and the Range Rover of the same period.
Post by cyf on Dec 22, 2011 17:37:29 GMT
and what about the chromework, redsunbeam?
tonys
Post by tonys on Dec 22, 2011 20:27:05 GMT
An excellent thread, first time I've seen it.
I've always been a big fan of the original look, but this is excellent work . Looking forward to seeing the end result.
What are the wheels from originally?
Post by redsunbeam on Dec 23, 2011 8:00:34 GMT
Tonys, wheels are from a jeep grand cherokee, i think it was a 2002 model - everso cheap. Cyf, i am removing the bumpers and the side stripe and using the sidelights as indicators. Ive had a play with the back end too, the two rear reflectors are now the reversing light and a fog light and i am using light bolts for the number plate.
Post by cyf on Dec 23, 2011 9:01:19 GMT
Thank you. I know it's a thread about the engine but I'm very interested by the bodywork as it's the modifications i want to do in the future.
Post by corbin on Jan 7, 2012 13:31:01 GMT
Post by redsunbeam on Jan 8, 2012 14:56:18 GMT
Corbin, i have to ask - what makes you think i'm not aware of the rules and regs regarding radically altered vehicles?
Post by corbin on Jan 8, 2012 19:17:37 GMT
I have no idea if you do or not. I admire what you are doing. I myself have been scared off from modifications of your complexity. As it stands at the moment I'm not sure if these regulations are being implemented now( hope not) but fear they may soon. The reason for my post was to give some in-site that may be planing mods, and may encounter unforeseen expense as these regulations may not be general knowledge.
Post by colnerov on Jan 9, 2012 0:07:50 GMT
Hi, Corbin. I am not having a go, But I take your point. As you alluded to with your link and the points system, Redsunbeam has exceeded the minimum number of points. At least nowadays it is quantifiable, there was a time when some people were taking Range Rovers, shortening the chassis, perching series 1 Land Rover bodies on top and nailing the series 1 number plate front and rear and driving it tax free. Like lot's of regulations they are not rigidly enforced but are there when things go wrong.
Colin
Post by regprescott on Mar 27, 2012 15:49:20 GMT
Interested to see if you the Jensen axle in yet and how you managed it. Have you got the 2.88 or the 3.0 ratio. Reg
Post by enigmas on Mar 28, 2012 10:22:49 GMT
I can't help but chip in here. Modifying or building a car to your vision is a passion and can be very addictive. It's an element of individual expression and is an end in itself. There's a whole counter culture 'out-there' building interesting, weird and unique stuff whether its cars, motorbikes, boats or whatever. There is so much conformity in the civilised western world these days that many people have lost the ability to express themselves either in words or maleable materials. It's often about the journey and the challenge...and if the will is there, it can be registered. Enough of that. Fear is the enemy. Maintain your passion for this project Redsunbeam. I'm enjoying it!
Post by redsunbeam on May 27, 2012 18:19:30 GMT
Post by enigmas on May 28, 2012 3:06:59 GMT
Nice work. It's interesting to see the module and wiring in position.
Post by redsunbeam on Jun 24, 2012 16:45:24 GMT
Close enough to running that i thought the old girl deserved her new insert for the tunnel cover. The V8 logo is embroided in. One of the old boys at work has an embroidery business on the side and did it for me.
Post by redsunbeam on Jun 24, 2012 18:25:51 GMT
