Post by Roy of the Rovers on Jun 25, 2012 11:30:15 GMT
Wheres the You tube video of you thrashing down the street??! Or is that just in New Zealand Would love to hear it!
Post by redsunbeam on Jun 25, 2012 13:44:02 GMT
That sounds very irresponsible roy and cannot be condoned on this forum.
Post by Roy of the Rovers on Jun 25, 2012 21:21:42 GMT
Amen So when is the link coming up?
Post by petervdvelde on Jun 26, 2012 17:28:14 GMT
Neil,
Good job, nice work. I did a rover V8 conversion on a MGB but that's been done so often that every pitfall is known so much much easier
Post by redsunbeam on Jul 7, 2012 12:47:37 GMT
Sorry Roy, still no video. No video camera. Have a still instead. She went straight through the mot on monday, just waiting for some dry weather to have a proper play. I have only been out in the wet so far and its a bit of a handful. ;D
Post by redsunbeam on Jul 29, 2013 19:24:21 GMT
Post by Roy of the Rovers on Aug 5, 2013 21:28:40 GMT
Does the bonnet close or are you going to have to 'bulge'?!
Post by eightofthem (Andy) on Aug 6, 2013 4:48:13 GMT
Does the bonnet close or are you going to have to 'bulge'?! Roy the bonnet might close, but driving it may still give you a bit of a bulge!
Post by redsunbeam on Aug 6, 2013 7:35:15 GMT
Does the bonnet close or are you going to have to 'bulge'?! If i got the measurements right when i put the engine in, it should go in without a bulge. It will nestle in the V of the engine leaving the pulley just above the thermostat housing that you can see. Because i'm only going to run fairly low boost to start off with - high boost would need bigger injectors and a stand alone ecu which is getting too expensive, theres no neccesity for charge cooling which would go under the charger raising it up. I'll know better once i've fabbed the manifold for it to go on.
Post by redsunbeam on Mar 25, 2014 12:00:38 GMT
Have been quietly collecting bits for the charger install, at the moment this is what we have, Consisting of Mustang M90 supercharger, Jag XJR intercoolers and a homemade adapter plate.
Post by pipetech on Jul 30, 2016 22:00:55 GMT
Hello Can you tell me what steering rack you are using ie what make and model car did it come from. I am wanting to do a similar conversion to my p5b.
Many thanks
Len
