Post by eightofthem (Andy) on Apr 1, 2012 21:46:05 GMT
Just a quicky,are the prop shaft u/j the same as land rover series???
Post by Phil Nottingham on Apr 2, 2012 17:17:00 GMT
Sometimes!
Dare I suggest SEARCH!
I have them in mine and they have lasted longer than the HS versions at 4 times the cost but then some may disagree
Post by eightofthem (Andy) on Apr 2, 2012 19:29:24 GMT
Guilty as charged,sorry phil did not have time to search last night,was too late and i was short on time . On the plus side more to find on the next search . Thanks for the info, will order one tonight.
Post by Phil Nottingham on Apr 2, 2012 21:09:07 GMT
You need the later type fitted to 2A and S3. The quality and its consistence of modern LR spares leaves something to be desired as nothing seems to be made in the UK
Post by eightofthem (Andy) on Apr 3, 2012 14:32:31 GMT
Part numbers are Hardy spicer 18196 / HS166 Unipart GUJ117 / GUJ1125 Land rover RTC3346 QH QL2104 Also propshaft center bearing f*g 6206.2ZR (shielded ball bearing 30x62x16 ) sorry will not let me put in the makers name fag so it is short for cigarette
