Post by Deleted on May 18, 2012 10:14:11 GMT
Does anybody know where I can get some saloon rear door lower window channels ( they are metal & run inside the door, clip on to the ends of the upper stainless channels and then bolt to the door frame), .
Mine have rusted away completely - I can't be the only one to have this problem
regards Baden Gooch 1959 Mk1 (coming along slowly)
Post by Pete Collins on May 18, 2012 11:29:19 GMT
Does anybody know where I can get some saloon rear door lower window channels ( they are metal & run inside the door, clip on to the ends of the upper stainless channels and then bolt to the door frame), . Mine have rusted away completely - I can't be the only one to have this problem regards Baden Gooch 1959 Mk1 (coming along slowly) Hi Baden What part of the world are you in? You have not filled in your location in you profile.
Post by Deleted on May 18, 2012 12:50:27 GMT
Near Cambridge
Post by David on May 18, 2012 16:18:44 GMT
Try David Green, he is your nearest P5 specialist and a regular (forum name is davidg) on here: www.davidgreen-p5.co.uk
Post by johnwp5bcoupe on May 19, 2012 9:07:04 GMT
Where near Cambridge? drop me an email not tooooo far away
Post by Deleted on May 19, 2012 9:52:35 GMT
Not far at all - Little Downham
Are the Mk1's different? - looking at my workshop manual - the window channell seems to be all in one piece - with no lower steel bits that clip on inside the door
Post by Phil Nottingham on May 19, 2012 12:56:03 GMT
Quite a lot of body bits are different on Mk1's - these did not have quarter lights so you may have to improvise
Post by Deleted on May 19, 2012 15:50:12 GMT
Hi
I have seem some aluminium channel with a felt lining on Paul Becks website, so I have ordered some, I should be able to cobble togetherwhat i want from that
regards
Baden
