Right then next up to be looked at is the rear clutch hub, and brake band.
We left off here last time.
Firstly if you have looked at the last post on the front clutch hub, you will see the tool thingy that you will need to make.
I will have a chat with the chaps who provided me with the new parts, and see if the correct tools are still available, and at what price, and maybee see if the club would be interested in them.
I used what i had to hand, you could go as far as you want with these. It is up to you.
I had a bearing race that had broken in half from my washing machine, this was the correct outside diameter 55 mm, and it was flat and true.
also in there was a brace strap from the washing machine, and a large thick washer.
I only had my large industrial stick welder with 3.5 rods, which are way to hefty for this. You need a mig, or thicker steel for the tool.
For the base tool you can use a nice square bit of timber such as kitchen worktop or M.D.F board. It needs to be flat, at least 30 mm thick, with a hole in the center for a threaded bar or rod.
You need to countersink the top and bottom of the hole to allow lock nuts to sit flush when you fit and lock off the treaded bar to the base.
I had a nice round billet of steel, so i welded my rod to it, and just used a washer to to pack it up over the weld.
Depending on the length of rod used you may need some extra washers and spacers, or you get fed up with spinning the top nut on / off.
Another tip is to use a piece of hose as a sleeve. fit this over the threaded bar when you fit your hubs over and down the rod, to save damaging the soft bearings.
Once the hub is sat on the base, just slide the sleeve off.
So in action it works like this. I have a few variations of these with various sizes of tubes for other uses.
So once that is done the first item on the menu is the brake band.
It is just like a brake shoe, and wears just the same way, and will cause the same damage if these wear down to the steel backing plate.
Check the amount of friction left,look for damage. If in doubt replace it with a new one.
My box has the self adjusting servo, so should have different type fitted. I will show you that later.
Bear in mind that the brake band actually uses the outside of the hub to clamp onto, and if you let these wear to excesss it will ruin the hub here
And you will then need to replace the hub as well.
Next up is to remove and look at the forward sun gear shaft.
You could leave this until later but it is first out so first seen.
Just ease it out of the rear clutch backwards.
Along with the shaft you should have two needle bearings, and a thrust washer. ( the thrust washer somtimes remains inside the planet set)
Inspect this shaft along the surfaces which run on the internal bearings for any wear.
And check the sun gear teeth for damage and wear, and the input splines on the front of the shaft for wear.
There are two front oil seal rings, and one rear nylon ring which need to be replaced. ( these are included in the overhaul kit )
this is the layout order.
On the front of the shaft you will find a valve, i could not find any reference to this, make sure it is clean and free.
Also inspect the sufaces of the sun gear, as the needle bearings sit against these directly, and seem to attract small particles of nasties.
Once satisfied with its re-usabillty , you need some new bits.
Identify the new seals you need
And refit them on the shaft, in their positions. The front two i alternated the joins, like piston rings, one oneside one the other.
And refit the rear ring seal
If the needles are good refit them. Use some vasaline to hold them in place on the shaft.
Rear first.
Then rear thrust washer, flat side against the needle.
Then the front needle.
Give it a coat of vasaline to protect it, then put it away in a clean bag for now.
Next on to the hub itself. it is a bit like the front hub.
First remove the thrust washer, check it over for wear.
Then remove the steel thrust washer ( note it has location lugs ) Check this out for wear as well.
Next remove the snap ring that retains the clutch pack.
Then remove the clutch pack steels and frictions. The first one is thicker than the rest.
Keep them in order if you plan on reusing them.
One steel one friction, remove them all one by one and lay them out in order.
There are five frictions and five steels.
The frictions are the same as the front clutch on mine, but it is worth checking them.
The steels however are dished.
Next we need to remove the piston spring, this is a chunky spring and is under a fair amount of tension.
It is held in place by a snap ring and a collar.
This is where you need your tool.
Set it up like so.
Once you have it in place load the spring down with the top nut on your tool to reveal the snap ring.
Now you can see why i choose the old bearing race ( or half of it )
You need to be able to get in there with circlip pliers to remove the snap ring.
It is tricky, try to use the chamfer where the thrust washer sits to help it out.
There it goes.
Once you remove it all from the tool, check this circlip out. Replace it if is worn or twisted.
Unload the tension on the spring, you can see how much it has risen with no load on it. Make sure your tool is man enough
Then remove said tool and hub, and remove the circlip, collar, and spring.
You can now see the piston. This is next out
As before on the front hub, use compressed air to remove the piston.
Apply it here.
Then remove the piston.
As I mentioned before, you can remove this without compressed air, but it is easier with, and you will need a compressor later.
And it has a seal on the outside rim here like the front did.
And another in the hub here.
These both need to be replaced, and come with the kit.
You can also see the torrington race bearing inside the shaft, check this and clean it out, replace it if worn or damaged.
On the back or rear of the hub you will find three large sealing rings.
These need to be removed and replaced. ( In the rebuild kit there are replacements, but these are steel, so i am going to order some teflon replacements and fit these.)
Remove them
Finally check the condition of the bearing inside the shaft.
This one is worn so i am replacing it. ( i will have to order one as i overlooked it first time)
So there we go. I have a shopping list of parts needed.
Give all the parts a good clean, and check over, and next time we will put it all back together.
Time for a cuppa.
