Post by PatMcCoy on Feb 9, 2005 14:09:04 GMT
Is it wise to do a engine flush? If so,Whats the best thing to use? Regards Pat
Post by dorsetflyer on Feb 9, 2005 16:06:49 GMT
Pat, it all depends on the state of the engine. If it is fairly clean providing you give it a good run first, then drain it straight away, you should be OK. If the engine is dirty and the oil very black, you can buy a Wynn's flushing additive to add to the oil, when it's hot, let it run for a while and then drain off. Which ever method you use, always change the oil filter. If you do want to flush it, the Wynn's treatment is by far the cheapest, as nowadays filling up with flushing oil is very expensive.
