Post by Deleted on Feb 17, 2005 8:07:00 GMT
The water flows through the matrix ok, but how does one expose the outer matrix so I can clean the fluff and pine needles off it? This car really needs the heaters as the windows are constantly misted making it unsafe to drive.
Post by Deleted on Feb 17, 2005 17:13:01 GMT
You have to remover the heater box to undo the casing and remove the matrix.
You will need new sealing foam strip otherwise air leaks will occur.
Tho old stuff will have turned to dust
