trymes
Post by trymes on Feb 22, 2013 20:23:37 GMT
It appears to me that, since the forum upgrade, there are a number of places where BBCode has stopped working. By BBCode, I mean the tags in square brackets that allow you to embed an image or link in a post, plus perform formatting tasks (eg: Bold, Italic), and the like.
Anyhow, if you look at my signature at the bottom of this post, it looks something like this:
Roverless for now...[hr]Want e-mail notifications of replies? - [url=http://roverp5.proboards.com /index.cgi?action=gotonewpost&board=probs&thread=5585]Click Here[/url] However, it should look like this:
However, when I edit my signature and click "preview", it displays properly.
You can also see a similar thing if you hover your mouse over "The Rover P5 Club forum" in the grey area above, directly under "Home" in the top menu. When you do that, a small menu will drop down, and you can see that the first entry has a color tag in it that we should not be able to see.
While I am nit-picking, the "f" in "forum" should be capitalized...
Anyhow, this is not a big deal, but I have seen this same issue crop up with others' signatures. In the end, I imagine that some things will have to be changed for the upgraded forum (like removing the color tag from the menu item above), while other things, like the signature display problem, can likely be fixed by changing a setting somewhere.
Thought I would mention it,
Tom
PS: Am I missing something, or is there no preview button in the compose window?
Post by Warwick on Feb 23, 2013 1:56:55 GMT
I gave up trying to fix mine and deleted it.
trymes
Post by trymes on Feb 23, 2013 3:29:32 GMT
Indeed. This can't be fixed by editing your signature. Something will have to be fixed in the underlying forum software...or we'll just have to get used to it!
trymes
Post by trymes on Apr 1, 2013 15:42:38 GMT
A bit of an update here: This post in the ProBoards support forum indicates that there is a setting in the admin pages for the forum to enable BBCode in signature (see the first reply). So...Admins, can you please enable this setting? Tom
