Post by iambiggles on Jun 7, 2005 20:50:18 GMT
I just picked up my Coupe today and for various reasons (that I'll not go into) it come with no manual or documentation.
My questions are about the controls.
1) Where is the screen wash button? 2) The three buttons on the center console.... I know the middle one is the Cigar Lighter (obviously), but what are the other two for?? I tried using them but nowt seems to happen!
Many thanks in advance.
Grant
Post by Deleted on Jun 7, 2005 20:56:50 GMT
You need the handbook! They are readily available new or secondhand
The WWasher is on the Left side of the Binacle
One switch should have a white button lens in it and this was for the often fitted heated rear screen (LHS). The other plain one is for the stndard built in foglights which only work with lighting switch on the column up and the main binnacle light switch swithed to the right.
Its essential to join the P5OC and you will hav ethe benefit of a bimonthly mag - also look at the full club website
Post by iambiggles on Jun 8, 2005 8:51:39 GMT
You need the handbook! They are readily available new or secondhand The WWasher is on the Left side of the Binacle One switch should have a white button lens in it and this was for the often fitted heated rear screen (LHS). The other plain one is for the stndard built in foglights which only work with lighting switch on the column up and the main binnacle light switch swithed to the right. Its essential to join the P5OC and you will hav ethe benefit of a bimonthly mag - also look at the full club website I most certainly do need one - and a Workshop manual too - both on order as we speak (or rather as I write ) Many thanks for the reply - at all makes sense now.
