Post by Deleted on Nov 24, 2005 17:21:18 GMT
I have taken the heater matrix out and cleaned it. Lubed all the linkages and spindles. It still wont heat the car properly even on a long run. Any ideas?
Post by Phil Nottingham on Nov 24, 2005 18:27:28 GMT
Is the matrix getting hot ie the valve is fully open so as to let hot water in?
The linkages have to be adjusted spot on as its an cold/hot air blend affair.
Richard Stennet did an excellent article in Take 5 some years ago which does work
Post by Deleted on Nov 25, 2005 9:35:51 GMT
I did replace the diaphragm valve which means that the regs got messed up. Can I get that article?
Post by Deleted on Nov 25, 2005 18:34:10 GMT
The matrix is in the car so i cannot tell if it is hot. I thought that the summer/ winter valve would have had lettering on it but i could not see any. Is it up or down for winter?
Post by Phil Nottingham on Nov 25, 2005 19:27:29 GMT
I will look tomorrow - mine is permanently on in this freezing weather and its really warm in the car!
Post by Phil Nottingham on Nov 27, 2005 9:58:53 GMT
Fully open the valve lever is facing to the front grill
