Post by Deleted on Mar 24, 2006 19:45:21 GMT
Sometimes I get exhaust fumes in the car - especially on overrun with a window open - any ideas?
Post by Kev on Mar 24, 2006 19:53:25 GMT
close the window ?
Post by dorsetflyer on Mar 24, 2006 20:19:27 GMT
A badly fitting or totally perished boot seal will give this condition. Exhaust fumes tend to travel up the boot lid and so through the seal. You can tell this by the amount of dirt that accumulates on the lower half of the lid and also the rear bumper.
Post by Deleted on Mar 24, 2006 21:09:46 GMT
Thanks John - I suspected that and tried re-sealing but it might not have sealed very well - I will look again. Thanks Kev - I knew someone would say that! When I worked in rural Wales many years ago I complained to my farmer employer that my Mk11 Landrover leaked petrol when filled over half full - 'Well, don't fill 'im over 'alf full then!' - was his solution. You would get on!
Post by Deleted on Mar 25, 2006 12:01:45 GMT
A leaking rear box will give this problem. Put your foot over the tailpipes and listen for leaks.
Post by glennr on Mar 25, 2006 14:37:34 GMT
It may be worth checking for any oil leaks that may be dropping onto the exhaust pipe. Does it smoke straight away or after a while? I liked Kev's advice. ;D
Post by dorsetflyer on Mar 25, 2006 16:13:16 GMT
Glenn I think you may have missed the point of the question. (put it down to age maybe). It was exhaust fumes and not burning oil fumes. Oil fumes give off quite an acrid smell so are very distinctive.
If the seal has been re-set and it still does it maybe the bootlid is not making a complete a complete seal all the way round. Try adjusting the lock so it's a slam shut. There are other holes in the boot lid and are enough to let fumes in. It's a process of elimination. Good luck.
Even on modern hatchbacks they advise not to travel far with large objects in the boot area where you have to tie the lid or not as the case may be otherwise it will suck in the exhaust fumes.
Post by glennr on Mar 25, 2006 18:40:08 GMT
I note your point John but sometimes people may get confused what may be exhaust smoke or oil smoke. Anyway, I am going to take my teeth out, rub some linament into my aching bones and watch "Debbie does Dallas" now, where's my glasses?
Post by dorsetflyer on Mar 26, 2006 13:39:10 GMT
Wanna borrow a pair so you can find them. If I can't find my glasses I usually have to wear another pair so I can see them.
