Post by Deleted on Oct 5, 2006 8:37:47 GMT
hello peeps.
just a quick one for you. Does anyone no what the ride hight should be from the center of the wheel to the bottom of the wheel arch on the frount and rear of a p5b??
Mine just seams to be really high at the frount and low at the rear
thanx for you help
tony
Post by PatMcCoy on Oct 5, 2006 8:40:39 GMT
Use search Its been a topic on here before Its might be under leaf springs I sent you a message to see how you got on with those lights at speedshack any luck
Post by Deleted on Oct 5, 2006 8:45:30 GMT
just sent you on back. thanx mate.
i shall have a look now to see if i can find them
tony
Post by Phil Nottingham on Oct 5, 2006 9:14:02 GMT
The ride height is not set like this as the wing positioning varies so much - if you do a poll you will see how much they can vary! If the car looks level its probably OK but if the rear springs have sagged it will be much lower at the the back.
The front ride height must be adjusted by the torsion bars and by measuring the wishbones as set out in the W/s manual. This adjustment also affect the rear height as well
