phil1969
Any idea where I can get some burgundy paint for my 72 P5b Coupe
Post by phil1969 on Jun 1, 2014 16:18:05 GMT
Thinking of changing my P5b 3.5l Coupe to electronic ignition. Any recommendations and advice would've greatly appreciated. Is it worth it?
thanks
Phil
Post by Deleted on Jun 1, 2014 17:42:43 GMT
Very much so! In my case I used Lumenition. Also installed 90 HA battery. After that was as reliable as any modern car. Even in the depth of pre-global warming winter!
Post by Deleted on Jun 1, 2014 18:49:39 GMT
Thinking of changing my P5b 3.5l Coupe to electronic ignition. Any recommendations and advice would've greatly appreciated. Is it worth it? thanks Phil8 Fitted Lumenition system in 1988 and no problems since. Improved performance etc. Single points in a V8 with the original dizzy are going to be marginal at best. The optic system in Lumenition negates anything other than severe wear. Apart from Radial tyres, electronic ignition is the only mod a P5b needs
Vee
Post by Vee on Jun 1, 2014 21:23:03 GMT
Thinking of changing my P5b 3.5l Coupe to electronic ignition. Any recommendations and advice would've greatly appreciated. Is it worth it? thanks Phil I just fitted one from the Distributor Doctor and it is great, I am hoping to keep points and condenser as a backup but probably might never have to use. Yes worth it Vee
Post by djm16 on Jun 1, 2014 22:51:59 GMT
Pertronix, me.
Post by Jens Munk on Jun 2, 2014 10:13:14 GMT
I have used Pertronix on other cars for years and now also on my Rover. Works great!
Post by Colin McA on Jun 2, 2014 10:40:23 GMT
I have an Aldon magnetic points in my original rebuilt distributor.
I had it rebuilt by H&H ignition solutions who I can recommend. They will even supply a complete electronic unit for around £100, I think worth a call.
Colin
Post by barryr on Jun 2, 2014 19:29:06 GMT
I've got a powerspark kit ready to go in but need to change coil to non ballasted type also. Not got round to it yet. Very good value and can flip points back in easily if required.
Allan NZ P5b
1971 p5b Auckland New Zealand
Post by Allan NZ P5b on Jun 11, 2014 0:54:23 GMT
Added Pertronix in 2004 to my p5b, never had a problem since, but didn't have much of a problem prior either just didn't want the hassle.
gollop
Post by gollop on Jun 12, 2014 7:35:03 GMT
I've just added a 123ignition and gotta say its fantastic BUT deffo on the very pricey scale.
Post by Simon H on Jun 12, 2014 20:22:56 GMT
And I've fitted a Powerspark dizzy coupled with a Aldon Amythyst programmable controller which allows switching between 2 advance curves for petrol and LPG.
Post by enigmas on Jun 12, 2014 22:40:02 GMT
Simon could I have some more information on your programmable ignition please.
Post by Simon H on Jun 12, 2014 23:26:08 GMT
Enigmas, I saw the Powerspark dizzy on Ebay - click here and asked the vendor about running it with petrol and LPG. They came up with the combination of their dizzy and the Aldon Amythyst controller. The dizzy supplied to me is customised in that it has vacuum and centrifugal advance disabled (the Aldon Amythyst deals with all that stuff). The Aldon allows 2 ignition advance maps to be selected at the flick of a switch. It can store about 10 maps but can only have 2 in active service at a time. In my case the map advances about 18 degrees when switching to LPG but it could equally be set up for road and track, or economy and race for a single fuel car. Ignition maps are fully programmable via the supplied software. The package cost around £350 including dizzy, Aldon Amythyst and a suitable Lucas coil. The contact details of the guy I dealt with are below. please feel free to ask if you need any more info. Aidan Vellender Customer Support Powerspark Ignition LTD Unit 16 Sanders Road Bromsgrove B61 7DG www.simonbbc.comOffice: (+44) 01527 889 453 Mon-Fri 10AM-5:30PM GMT
