Dimi
Post by Dimi on Feb 24, 2015 18:43:53 GMT
Hi I'm a new member from Italy. I just saved a P5B from crushing. is reduced very bad, I took pictures. I do not have documents and I have no idea what year it is. I apologize for my poor English "macaroni" !!! Dimitri
Post by harvey on Feb 24, 2015 19:33:55 GMT
Looks like it has a sliding steel sunroof. I can't say I've seen many of those in P5Bs.
Dimi
Post by Dimi on Feb 24, 2015 19:43:25 GMT
Looks like it has a sliding steel sunroof. I can't say I've seen many of those in P5Bs. Yes, it has a sliding steel sunroof. I "would like to" restore it, there's a lot of work, very much work ..... The first thing you need in Italy, is the technical data / datasheet of the car. I can not find. The engine number where you see ??
Post by harvey on Feb 24, 2015 19:48:00 GMT
The engine number where you see ?? The engine number is on the block behind the left hand cylinder head. (Left hand is the same side as your steering wheel)
Post by harvey on Feb 24, 2015 19:50:36 GMT
That's a picture taken looking downwards over the left hand head.
Dimi
Post by Dimi on Feb 24, 2015 19:55:46 GMT
The engine number where you see ?? The engine number is on the block behind the left hand cylinder head. (Left hand is the same side as your steering wheel) Hi Harvey, thanks !!!!!
haikuhead
Post by haikuhead on Feb 24, 2015 20:08:11 GMT
Phew! That's quite a job you've taken on Dimi but more power to you if you can save that P5B from the crusher and give it a new home.
Post by Phil Nottingham on Feb 24, 2015 20:46:07 GMT
1969/70 model at least as got the AED and thin back seats
Post by Warwick on Feb 25, 2015 2:34:40 GMT
Dimi
Post by Dimi on Feb 25, 2015 6:45:07 GMT
1969/70 model at least as got the AED and thin back seats Thanks Phil , AED ??
Dimi
Post by Dimi on Feb 25, 2015 6:51:45 GMT
Thanks Warwick a great job, it seems my car. Does anyone know where I can find the technical data / datasheet / fiches Rover P5B ??
Post by johnwp5bcoupe on Feb 25, 2015 8:11:10 GMT
The AED that Phil is referring to is the Automatic Enrichment Device. It was an automatic cold starting system to replace the manual choke. It is visible in your photo so that enabled Phil to identify when the car was made. Earlier models had the manual choke. When you say technical data sheets, do you mean the workshop manual (book)? If so, you can purchase a new reproduction from the Rover P5 Club, or you may find second-hand copies on eBay. Look on the left-hand side near the top of the forum home page for a link to the club's website. The early V8's had the AED and the later ones were manual I would think seriously about starting this restoration due to the state of the car the cost involved and parts availability in Italy
Post by guidedog on Feb 25, 2015 9:50:30 GMT
Welcome Dimitri, I have agree with John, think with your head not your heart you will spend thousands of euro's getting the car right. You could get to a point when you have had enough then stop. Look up Peter de Veldes work you will get some idea what is involved. I love your idea but....
Think carefully. Good luck
Bob
Dimi
Post by Dimi on Feb 25, 2015 10:15:42 GMT
Hi, the workshop manual I bought the club. The datasheet is a document for approval. example: I work in an engineering company .... The cost will be spare parts and sheet metal !!!!
Dimi
Post by Dimi on Feb 26, 2015 6:43:38 GMT
Thanks for the info. Question: with the number of the chassis, you can trace the history of the car ??
Dimitri
Post by GlennR on Feb 26, 2015 7:19:15 GMT
Hi Dimi, take it from me, have a really good think about taking this project on. It is only my suggestion but I would spend my money on a better example.It's not just the money it is the time that is involved. Whatever your descision though...the best of luck
Dimi
Post by Dimi on Feb 26, 2015 12:17:20 GMT
Chassis number :
Post by Deleted on Feb 26, 2015 12:26:42 GMT
Chassis number : That chassis number indicates that your car is an export LHD Saloon from 1970. The numbers commenced at 84300235 for 1970. The "D" means that the lower BC pillars have been modified to take inertia reel seatbelts. This information courtesy of "The Post-War Rover P4 & P5" by James Taylor.
Post by petervdvelde on Feb 26, 2015 12:30:22 GMT
Dimitri,
I can't help you with the history details of your car. To get it registered, it could be that the testers are not happy with a screwed on plate showing the chassis nr. Look at your subframe. On the top of the LH subframe bracket where the bracket of the front bumper is attached to the subframe, the chassis nr is stamped into the subframe. There will be a lot of dirt on it.
Dimi
Post by Dimi on Feb 26, 2015 12:38:34 GMT
Thanks for important information.
Dimitri
Dimi
Post by Dimi on Feb 26, 2015 15:12:24 GMT
Dimitri, I can't help you with the history details of your car. To get it registered, it could be that the testers are not happy with a screwed on plate showing the chassis nr. Look at your subframe. On the top of the LH subframe bracket where the bracket of the front bumper is attached to the subframe, the chassis nr is stamped into the subframe. There will be a lot of dirt on it. Peter Peter, You mean this ?? Dimitri
Post by petervdvelde on Feb 26, 2015 21:24:21 GMT
Dimitri, No, i didn't mean that. Its near the left hand front wheel. It the area on the subframe which shows some surface rust above the 2 bolts from the front bumper mounting bracket. Regards Peter
Post by Eric R on Feb 27, 2015 9:44:30 GMT
I agree with ^. I spent around £19,000 (26,000 Euro) which is more than the finished car is worth. My opinion is - close your eyes and let it go and spend less money of a finished car.
Dimi
Post by Dimi on Feb 27, 2015 17:55:33 GMT
I agree with ^. I spent around £19,000 (26,000 Euro) which is more than the finished car is worth. My opinion is - close your eyes and let it go and spend less money of a finished car. Hi Eric, 26000 Euro of pieces? Or including work? Dimitri
Dimi
Post by Dimi on Feb 27, 2015 17:58:48 GMT
Dimitri, No, i didn't mean that. Its near the left hand front wheel. It the area on the subframe which shows some surface rust above the 2 bolts from the front bumper mounting bracket. Regards Peter (8?)2003(8?) The first and the last, you do not really understand. Dimitri
